Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Jeff (guest)
Guest
Posts: n/a
Hello, I have a 2006 R53 Cooper S and have an odd fueling issue. If the tank is less than half full, hard left turns result in a loss of fuel pressure that lasts a couple of seconds after the turn is made. No other driving conditions have made the symptoms occur, and a relatively full tank is fine. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Fuel Pump and Filter Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 01-05-2017, 08:23 AM
Nick at Pelican Parts's Avatar
Could be an issue with the siphon not transferring fuel fast enough or a weak fuel pump. I would perform a fuel delivery system test. Check fuel pressure, volume and quality. This can rule out the pump.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Also, check your fuel filter. Not saying it's your issue, but it's a good thing to inspect/replace when needed. Fueling items if needed: PelicanParts.com - 2006 Mini Cooper S Hatchback - Fuel & Intake.
Old 01-06-2017, 09:33 AM
