Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Danny (guest)
Guest
Posts: n/a
Upon replacing the valve cover I forgot to disconnect the battery and my question is; would not erasing fault codes affect the performance of the car? These faults include, sensors on and around the valve cover, removed ignition coils and I also replaced the vacuum pump. All these were done while the battery was still connected.
I am talking about a Mini Cooper S , 2007, N14/R56
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 01-18-2017, 06:48 AM
Nick at Pelican Parts's Avatar
Yes, if the codes are performance based, engine power can be decreased. best bet is to clear the faults. You can to cycling the key 40 times to see if they clear.
- Nick
