Guest
Posts: n/a
Your article says "...most manufacturers consider the consumption of one quart of oil per 1000 miles or longer acceptable..."
I am replenishing my '07 "S" with a quart nearly every 1000 miles. Last oil change 70K Mi. I also replaced the plugs. fine wire center electrode type When I pulled number four cylinder plug, there was no ground electrode. It was gone all the way up to the bottom thread. I bought the car used and I don't know when this happened. My questions are these; Should I be concerned that my cylinder wall is scored because of the remnants of the electrode and that is causing excessive blow by and increased oil consumption? And, can I do a compression test to see if the number four is scored __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Oil Consumption Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article |
You can perform a compression test and leak down. I would assume you would have a misfire is there was an issue.
- Nick |
Administrator
Was there any symptoms that lead you to the replacement of the plugs or did you just replace them as a maintenance job?
Leak down and engine compression test tools here: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Engine Tools - Page 2 |
