2009 mini 1.4 runs good when under load you can here a chatter and the the vehicle smokes a lot?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Check your oil level ASAP!!! Sounds like a low oil level issue.
- Casey |
You may have already done damage. The timing guides wear from lack of lubrication and running low on engine oil. This can cause timing chain rattle at start up, noise when running and worse-case scenario a jumped timing engine.
More info here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
| All times are GMT -8. The time now is 03:41 PM. |
