Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
firstcoast (guest)
Guest
Posts: n/a
Looking at Fig 27. How do you install the and set the pretensioner to 6nm if the camshaft sprockets haven't yet been installed? Wouldn't there be zero tension on the chain thus no tension on the pretension tool.
I'm currently at the point where I start my reassembly and just want to make sure I have all the angles understood.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 02-20-2017, 10:30 AM
I just spoke to Nick and he says to follow the instructions, screw the tool into the engine, then tighten the center tensioning part of the tool to .6nm, then install the sprockets.
- Casey
