Guest
Posts: n/a
Hi, I have a Mini Cooper S 07. How can I know when I need to replace my valve cover? I see the 2 vacuum hoses with oil inside.Does the 2 hoses should be totally dry without any signal of oil? Not sure if a valve cover replace come soon or actually my car has a bad valve cover. Thank you!
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
See Dan's post above. Check those other items first, then make the call.
- Casey |
Administrator
Can you post a picture? If the vacuum pipe/hose on the valve cover near the intake is leaking, it may be time to replace the hose. Do you see oil anywhere else on the valve cover?
More info on that item here: http://forums.pelicanparts.com/bmw-mini/946244-where-does-vacuum-pipe-go-how-difficult-change.html |
