Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Nick (guest)
Guest
Posts: n/a
https://www.northamericanmotoring.com/forums/r56-hatch-talk-2007/243951-pcv-mystery-solved.html
Here is a great view of what the PCV in the valve cover looks like. There is a lot more going on in there than I thought. This is probably the reason they cost so much. Enjoy!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 03-22-2017, 04:43 AM
Nick at Pelican Parts's Avatar
Thanks for sharing!
- Nick
Nick (guest)
Guest
Posts: n/a
I use to be able to pull my Oil filling cap while the engine is running. Now there is so much vacuum I can't pull it off with the engine running. What would cause this? I'm thinking it could be a faulty electric PCV at the turbo inlet? Am I right or is it the Valve cover?
Old 03-22-2017, 04:45 AM
Could be the crankcase breather valve in the valve cover. If the diaphragm fails, it will put too much vacuum in the crankcase.
- Nick
