Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mac (guest)
Guest
Posts: n/a
Thanks Nick for these instructions.Both the transmission plugs on my 2006 MCS are 8mm hex keys. Your suggestion to purchase an inexpensive hand pump worked well. Here is my question, I installed a crush washer with the drain plug, but didn't realize the fill plug should have a washer as well. How critical is that? If important I will install washer next time I am under the car.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 03-22-2017, 04:31 AM
Nick at Pelican Parts's Avatar
I would replace next time. BUT - A lot of people re-use, I never do, for prevention of issues. You will probably be ok though.
- Nick
