Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
SteveO (guest)
Guest
Posts: n/a
R56 what is this red pull tab on valve cover?
2010 mini cooper. I bought a new valve cover. It has a red pull tab. Do I pull it or what? No other parts came with the cover
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 03-14-2017, 07:06 AM
Nick at Pelican Parts's Avatar
Red pull tab, can you share a photo of the tab?
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Are you talking about this red tab in the photo below?
If so, remove it. You are supposed to reinsert the valve cap once you remove the red pull tab.
Old 03-14-2017, 10:17 AM
Nick (guest)
Guest
Posts: n/a
On the new valve cover do I pull out the red pull ring and install the valve with the green oring in its place
Old 03-15-2017, 06:28 AM
Yes you do. Thanks for getting back to me with photos.
- Nick
Nick (guest)
Guest
Posts: n/a
Here is the red ring.
Old 03-15-2017, 06:29 AM
- Nick
