Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mdmini92 (guest)
Guest
Posts: n/a
So i did the drain and fill on my 08 cooper s r56 replaced the filter as well but still having issues with 4th, 5th ,and 6th gear from slipping and not catching. I was told it may be a solenoid issue but i have no solenoid fault issue codes. The only codes i get are for ratio monitoring for 4th and 5th. 4th has improved some since the drain and fill but 5th and 6th not so much. Any ideas??
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Automatic Transmission Fluid Change (R50/R52/R53/R56/R57 2001-2015) | Pelican Parts DIY Maintenance Article
Old 03-17-2017, 12:45 PM
I had a customer car that did that and it ended up being the valve body. It is a very common failure on the Aisin transmission.
- Casey
