Guest
Posts: n/a
so i just bought 2003 r53 s manual. it has shifting problem owner had replaced clutch on his own. after that it has problem to shift in gears and you can't shift to 6th gear. what can it be
thanks! __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Shift Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
Could be trans mount, engine mount, shift cable, shifter adjustment or a problem with the gearbox itself.
- Casey |
Thread Tools | |
Rate This Thread | |
