Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
kevin (guest)
Guest
Posts: n/a
Looks like have a leak at the front drivers corner. Looking more closely, almost looks like there's a hole in the valve cover - see attached. Is this normal? Asking since need to determine if it's just the gasket or gasket & cover replacement is needed.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 08:20 AM
Nick at Pelican Parts's Avatar
That is not normal. The valve cover is damaged. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Definitely replace. What R56 do you have? Covers here: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Cylinder Head & Valvetrain - Page 1
Old 04-24-2017, 12:35 PM
