-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Power Steering Pump Replacement (http://forums.pelicanparts.com/mini-discussion-forum/953816-question-power-steering-pump-replacement.html)
joggie (guest) 04-19-2017 06:33 AM
Nick..do the psp has any thing to do with the computer,a machanic say to me that if the psp is change need to reprogram the computer in order to read the motor and the fan, is that true?..!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 04-19-2017 06:33 AM
What year vehicle? On R50, no programming needed.
- Nick
Luccia at Pelican Parts 04-24-2017 12:36 PM
The first gen MINI does not require any programming of any sort. However, the R56 system is different from the first gen as there is no hydraulic system and it has an electrical assist rack. The power steering rack comes with an integrated motor and does not require programming with a new unit. It may require programming with a used unit. Let me know what MINI you have and I can help you find a replacement if needed.
