Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
joggie (guest)
Guest
Posts: n/a
Nick..do the psp has any thing to do with the computer,a machanic say to me that if the psp is change need to reprogram the computer in order to read the motor and the fan, is that true?..!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 07:33 AM
Nick at Pelican Parts's Avatar
What year vehicle? On R50, no programming needed.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
The first gen MINI does not require any programming of any sort. However, the R56 system is different from the first gen as there is no hydraulic system and it has an electrical assist rack. The power steering rack comes with an integrated motor and does not require programming with a new unit. It may require programming with a used unit. Let me know what MINI you have and I can help you find a replacement if needed.
Old 04-24-2017, 01:36 PM
