Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Amithlon (guest)
Guest
Posts: n/a
Used your very thorough text and photo's to remove the window assembly from my drivers side right side like in U.K..
However the gearbox spline on the outside had been sheared off. no glues would work, epoxy, cyanoacylate, plastic glues etc, couldn't handle the strain. the motor has a yellow connector, where can i get one of these none on fleabay am willing to pay you guys a commission to get one.
or at least direct me to a source.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Window Regulator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 08:01 AM
Nick at Pelican Parts's Avatar
If sheared, I would assume the regulator is faulty as well. i would replace the motor with regulator. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
What are the last 7 digits of your MINI's vin number? I can direct you to the correct part that you need to purchase in our catalog.
Old 04-19-2017, 11:59 AM
