-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Charcoal Canister Replacing (http://forums.pelicanparts.com/mini-discussion-forum/953836-question-charcoal-canister-replacing.html)
Bob H (guest) 04-19-2017 07:16 AM
I am trying to remove the two 6mm allen screws that hold the charcoal canister. The screws will rotate, with some resistance and then *thump* into position after rotating exactly 90 degrees. It acts like there is a square nylon nut that is rotating along with the screw. I cannot see or feel the nut so I can�t hold it from turning. Has anyone encountered this and know a solution?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Charcoal Canister Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 04-19-2017 07:16 AM
The nut inside the plastic has failed. Your only option is to try to hold them still with visegrips while loosening. If that doesn't work, drill the bolts out and replace the bolts and mounting bracket.
- Nick
