Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
mosport (guest)
Guest
Posts: n/a
when installing the variable intake gear, where should it be for advance? ive timed properly and it runs rough only at idle now.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 07:22 AM
Nick at Pelican Parts's Avatar
The engine has to be locked in place using timing tool kit shown in article. Did you use this tool kit?
- Nick
