Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
JayNav38 (guest)
Guest
Posts: n/a
I have an 03 Mini Cooper. I noticed when my car is off it leaks coolant from the small hose connected to my water pump. The line is worn in the ends and the clamps have corrosion. Should I replace the pump or just the hose and the clamps
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R50 Water Pump Replacement (R50 2001-2006) | Pelican Parts DIY Maintenance Article
Old 04-26-2017, 07:52 AM
Nick at Pelican Parts's Avatar
Replace the hose. Best bet. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
If the hose is leaking, replace the hose. Is it item # 11 on the diagram below? What are the last 7 digits of your R50's vin number? The radiator to water pump hose is here: 2003 Mini Cooper Base Hatchback - Radiator to Water Pump hose. I can confirm with your vin, but I believe that should be the one you need.
Old 04-26-2017, 10:19 AM
