Guest
Posts: n/a
Getting a 190 code and confirmed it is not bad wiring assuming it is 5V to ground on yellow and orange. Have pulled off the sensor so know it is not welded to the fuel rail. But YOU DON'T SELL THIS PART?!?!?!?!?!?! Please - take my money I want to buy this from you!!!!!
BTW this tech article was super helpful - thank you! not sure I agree about the "In addition, replace the high pressure fuel line." part at the end, if you are not swapping out the fuel rail, only the sensor, this would be unnecessary. __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Rail Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick |
Administrator
What year R56? If you have the last 7 digits of your vin I can help you find the part. If you can't find a part in our catalog we more than likely have it so please do not hesitate to give us a shout.
