-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Front Brake Pad Replacement (http://forums.pelicanparts.com/mini-discussion-forum/956090-question-front-brake-pad-replacement.html)
JaxPops (guest) 05-09-2017 06:09 AM
Yes, you guys are wrong, its not 17mm on the slide bolt. Your disinformation was very frustrating.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Front Brake Pad Replacement (R56 2007-2013) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 05-09-2017 06:09 AM
Looking at the photos the article had a 17mm wrench used. It is possible the caliper bracket was replaced and different size than factory was in p;lace. I have also seen these as 16mm.
- Nick
Luccia at Pelican Parts 05-10-2017 10:29 AM
Keep in mind that when your car was serviced before, parts may have been replaced with different size fasteners used in the replacement. Also, there could be a variation or difference with models. The sizes of the nuts and bolts we give may be different from what you have, so it is always good to be prepared with different size sockets and wrenches while working on your MINI.
