Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
steve (guest)
Guest
Posts: n/a
hello i have a 2008 mini cooper r56. i am stuck in limp mode, used a bmw/mini scanner and get fault codes:28B4 SME:Valvetronic servomotor, sluggish movement. i changed spark plugs, did replace a bad coil, cleaned both solenoids,oil looks clean...i am stuck not sure what else to do..any advice would be much appreciated. thank you.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valvetronic Faults (2007-2011) | Pelican Parts DIY Maintenance Article
Old 05-24-2017, 08:12 AM
Nick at Pelican Parts's Avatar
You either have a faulty VAlvetronic motor or faulty wiring to the motor.
- Nick
Nick, thanks for the reply....question on valvetronic motor. I am going to test, using a valvetronic from my friends 09 cooper. Do you think this is ok to do, before i order a new one? Removing the vavletronice has 3 screws, should it just pull out from there?
Old 05-30-2017, 10:05 PM
