Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
RuM (guest)
Guest
Posts: n/a
2011 Mini Cooper
Engine; N16 1600CC / 90kW
Manual
85k miles
Code P0015....should I replace the variable valve timing solenoid ?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 05-24-2017, 08:13 AM
Nick at Pelican Parts's Avatar
Yes, that is a common issue for that fault. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Also, might want to test your camshaft sensor: MINI Cooper R56 Camshaft Position Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article. Could definitely be VANOS as P0015 with MINI FC code 0x2D61 is VANOS, exahust: Closed-loop control fault, position not reached. 0x2845 is 'B' camshaft position timing over-retarded (bank 1) and 0x2D60 is VANOS, exhaust: closed-loop control fault, camshaft sticks. Depending on which one you have I've seen VANOS, skipped timing, or camshaft position sensor as the culprit. Report back with your findings!
VANOS sensor if needed: MINI Cooper R56 - VANOS
Old 06-09-2017, 09:49 AM
