Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
CamdenR56 (guest)
Guest
Posts: n/a
Hello, I have a 2010 Mini Cooper S and my car has at times left oil puddles towards front center on the garage floor. Also, every time I stop at a light or car is idle, there is smoke that comes out of the front part of the bonnet. As I continue to drive the smoke remains evident. I put on the AC to see if this helps. At times I think it does. My car only has 60k. I'm worried about driving it this way that it could cause something major like a fire etc..
What would you suggest is the problem?? Hoping you can help...thanks in advance...
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Oil Leak Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article
Old 06-13-2017, 07:29 AM
Nick at Pelican Parts's Avatar
Could be a turbocharger oil line or gasket on the engine. hard to say without seeing it. I would lift the vehicle and support it safely. Then inspect the engine for the source of the leak.
- Nick
