Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Minime73 (guest)
Guest
Posts: n/a
Hi, I have a 2005 Mini BASE and both of my rear lights aren't working but the brake lights work and all of the other lights are working fine. Would both bulbs go out at the same time? I'm wondering if it's the bulbs or a fuse and is there just one fuse that controls all the lights?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Lens and Bulb Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 06-13-2017, 07:09 AM
Nick at Pelican Parts's Avatar
I have seen two bulbs fail at once. I would start with one bulb, see if it has power and ground.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Once one bulb goes it's not unlikely for the partner bulb to fail. That is why it's recommended to replace bulbs in pairs. A good place to start would be what Nick said above.
Bulbs here if needed: 2005 Mini Cooper Base Hatchback - Lights and Lenses - Page 6
Old 06-13-2017, 08:37 AM
