Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
JorgeHRT (guest)
Guest
Posts: n/a
I changed the Vacuum pump o-ring, the small one because it was leaking oil. After i changed the O-ring, it was still leaking oil, any suggestions as to what should i do?? the ring that is against the block and vacuum pump
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Vacuum Pump Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 06-13-2017, 07:25 AM
Nick at Pelican Parts's Avatar
Check if the pump itself is leaking oil from the shaft. Might not be the o-ring.
- Nick
