-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Coolant Temperature and Oil Pressure Sensor Replacement (http://forums.pelicanparts.com/mini-discussion-forum/961431-question-coolant-temperature-oil-pressure-sensor-replacement.html)
RUGADIAR (guest) 06-26-2017 11:29 AM
I replaced my thermostat with a new coolant sensor. And now my hidden menu shows +++oC. I thought that the new sensor has a failure and replaced with the old one and shows the same +++oC.
Do you now how to show again the temp on the hidden menu? Should i disconnect the battery for a while? Its a MCS 2009.
Thank you.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 06-26-2017 11:29 AM
I don't have that info. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
