Guest
Posts: n/a
I replaced my thermostat with a new coolant sensor. And now my hidden menu shows +++oC. I thought that the new sensor has a failure and replaced with the old one and shows the same +++oC.
Do you now how to show again the temp on the hidden menu? Should i disconnect the battery for a while? Its a MCS 2009. Thank you. __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
I don't have that info. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick |
