-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Raditaor Service Position (http://forums.pelicanparts.com/mini-discussion-forum/961766-question-raditaor-service-position.html)
Taylor (guest) 06-29-2017 10:58 AM
Can the car be up on drive up ramps to get into radiator service mode or does the weight have to be off the wheels?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Radiator Support Service Position (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 06-29-2017 10:58 AM
Weight should remain off wheels. if on a two-post lift, you can slightly lower with wheels touching ground, but try to keep it minimal.
- Nick
Luccia at Pelican Parts 07-05-2017 08:52 AM
May want to look into the QuickJack unit if you don't have any other lifting options in your garage.
QuickJack Lifts - PelicanParts.com
