Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Taylor (guest)
Guest
Posts: n/a
Can the car be up on drive up ramps to get into radiator service mode or does the weight have to be off the wheels?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Radiator Support Service Position (2007-2011) | Pelican Parts DIY Maintenance Article
Old 06-29-2017, 10:58 AM
Nick at Pelican Parts's Avatar
Weight should remain off wheels. if on a two-post lift, you can slightly lower with wheels touching ground, but try to keep it minimal.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
May want to look into the QuickJack unit if you don't have any other lifting options in your garage.
QuickJack Lifts - PelicanParts.com
Old 07-05-2017, 08:52 AM
