Guest
Posts: n/a
I've just done fuel filter change. R56 MINI 2011 R56 Mini Cooper.
EvErything went ok... hard getting sump sucker position part on and then all positioned well. Problem: No mention of parts in fuel disconnect fitting so. didn't notice if a part came oout. What is up in that connector? any O-rings or. such... cause that's where I'm Getting a nasty shower oF a leak s __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Fuel Pump and Filter Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
The line has O-rings in it. If damaged or lost the line will leak.
- Nick |
