Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Co30op (guest)
Guest
Posts: n/a
Does anyone have the exact bolt size for the two bolts that attach the pump? The two bolts that need the 8mm socket. The head snapped on one of mine... the car's running ruff I'm assuming a vacuum leak... and need to replace it in the morning. But, I'd like to get the bolt before disassembling everything again.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Vacuum Pump Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 07-22-2017, 05:03 AM
Nick at Pelican Parts's Avatar
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what size they are.
- Nick
