Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Duchess (guest)
Guest
Posts: n/a
Hi, I probably should have read all the comments, but there were quite a few, is the 2 hour install time for the pump and the filter? If so, how long would you est the time would be for just the filter, if the seats are out? I have a 2005 Mini Cooper r52 base.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Fuel Pump and Filter Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 08-11-2017, 08:49 AM
Nick at Pelican Parts's Avatar
I would assume about 2 hours for the filter. You may get done sooner.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
The seats aren't too difficult to remove. As a note: Typically, if there are other articles we recommend checking out when doing the replacement of something in one article, that other article will give you an estimated time for the other item replacement. You'll want to add up all the times from all the articles (if there are any others than just the one).
Old 08-15-2017, 02:06 PM
