Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Taylor (guest)
Guest
Posts: n/a
What is the torque suppposed to be when reattaching the inner tie rod? I can only seem to find it for the outer and the pinch bolt
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Tie Rod End Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-12-2017, 06:59 AM
Nick at Pelican Parts's Avatar
I don’t have torque information.
I would suggest you grab a repair manual, you should own one. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799.
- Nick
