-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Power Steering Pump Replacement (http://forums.pelicanparts.com/mini-discussion-forum/966158-question-power-steering-pump-replacement.html)
Lole (guest) 08-11-2017 08:56 AM
Hi. I am just about to replace the steering pump on my wife's 2002 mini one 50,000 miles after I stupidly jump started it with the cables the wrong way round I know, I know. I've replaced the large food underneath the engine compartment fuse box and the smaller fuse above. Garage says diagnostics don't help. Before I crawl underneath and start, can you tell me if there is anything else electrical I should look at first? The car runs but no PS at all. No noises. Thanks in advance for your help.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 08-11-2017 08:56 AM
Check the fuses at the battery if equipped and any smaller fuses in the vehicle and the engine fuse box.
- Nick
