Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Heather (guest)
Guest
Posts: n/a
I have a mini cooper s convertible the car has 65000 on the clock and just recently coolant seems to be leaking somewhere it appears to leak just after I have run the car and left it standing, looked underneath the car and its dripping out at the bottom back end of the engine, anyone any ideas what this could be??
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Draining and Filling Cooling System (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-12-2017, 06:36 AM
Nick at Pelican Parts's Avatar
Could be the coolant pump or coolant pipe at back of engine.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Easiest and fastest way to track down a leak (if you don't think the 2 Nick suggested above are leaking) is to pressure test the system. This article can help: MINI Cooper R56 Cooling System Leak Test (2007-2011) | Pelican Parts DIY Maintenance Article. Let us know what you find.
Old 08-18-2017, 02:25 PM
