Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
minion (guest)
Guest
Posts: n/a
Hi. Feeling a little foolish. I did not mark the exact position of the control arm when I installed the bushings. I kind of guesstimated the angle of the control arm with respect to the subframe and eventually with the weight of the car when all the weight will be resting on the control arm. Since the subframe is still off the car, is there another way to make sure that the control arm is at the proper angle when installed on the bushing?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Control Arm Bushing and Ball Joint Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 08-18-2017, 06:15 AM
Nick at Pelican Parts's Avatar
Going by memory, the arrow on the bushing points straight ahead, parallel with ground.
- Nick
