Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Justin (guest)
Guest
Posts: n/a
Hey nick, have an 07 mini base n12b motor. Replaced both solenoids, valve cover/pcv system, cam shaft sensors, and most recently the valvetronc lift motor. Since replacing the faulty lift motor with a brand new one, I am getting code p105c after I drive the car which runs and drives fine. Any ideas? Thanks in advance!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valvetronic Faults (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-18-2017, 05:26 AM
Nick at Pelican Parts's Avatar
have you relearned the Valvetronic limit stops using an advanced MINI scan tool like Autologic?
- Nick
