| Guest
					Posts: n/a
			hello i have mini cooper r56 2007 128kw and i have big problem, i went to gas station to put some gas in car, and after i put gas in car i cant start him 5-10 min after that he start great, it happen two times! so after 3 months, car wont start i changed crankshaft sensor, and camshaft sensor but car still don't wont turn on, when i try to start it he is cranking but wont start. pls help me! __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Crankshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article | ||
|  08-18-2017, 05:28 AM |
| Moderator Join Date: Jul 2012 Location: New England
			I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume, quality and engine compression. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose. - Nick | ||
| Administrator Join Date: Feb 2015
			Did you check the DME for any fault codes? It's only when the gas tank is full? Never when it's half or on empty?
|  08-28-2017, 01:04 PM |
