-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Shift Cable Replacement (http://forums.pelicanparts.com/mini-discussion-forum/967740-question-shift-cable-replacement.html)
chrisroy02 (guest) 08-25-2017 06:47 AM
i have a 2008 mini cooper convertible base that is stuck in first gear. I changed the transmission fluid and filter without any result. i also hear a groaning noise on the right side when i first drive off and then it goes away. could that be a bearing or the drive axle? what should i try next
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Shift Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 08-25-2017 06:47 AM
You may have worn internal parts in the trans. First, remove the shift cables, can you manually shift the trans into neutral ?
- Nick
