Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
chrisroy02 (guest)
Guest
Posts: n/a
i have a 2008 mini cooper convertible base that is stuck in first gear. I changed the transmission fluid and filter without any result. i also hear a groaning noise on the right side when i first drive off and then it goes away. could that be a bearing or the drive axle? what should i try next
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Shift Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 08-25-2017, 07:47 AM
Nick at Pelican Parts's Avatar
You may have worn internal parts in the trans. First, remove the shift cables, can you manually shift the trans into neutral ?
- Nick
