-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharger Wastegate Testing (http://forums.pelicanparts.com/mini-discussion-forum/967744-question-turbocharger-wastegate-testing.html)
Mad at MINI (guest) 08-25-2017 06:50 AM
1 can the 2885 fault code be caused/ is it commonly caused by the recirc valve condensation issue, or does that throu a different fault?
2 if there is a waste gate issue play in linkage or bad actuator can either of those be repaired without replacing the whole turbo?
3 thank you so much for these tech articles!!!
This post was auto-generated based upon a question asked on our tech article page here: Mini R56 Testing the Engine Turbocharger Wastegate | R56 Cooper S Hatchback (2007-2013), R56 Cooper JCW Hatchback (2009-2013) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 08-25-2017 06:50 AM
1. Yes, usually the valve.
2. No parts available as far as I know.
3. Thanks!!
- Nick
