Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Orlando (guest)
Guest
Posts: n/a
My 2010 Cooper S is leaking oil, I believe it if from the valve cover, it is leaking on to the muffler making it burn and smell awful, also the oil is collecting on top of the transmission. Im replacing the head cover and seals. I noticed that the previous owner deleted the air breather hose at the right rear of the valve cover, same as image #4. Do I need to get a new hose and install it or it is not necessary? The hose goes from the valve cover to the intake manifold.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-25-2017, 06:57 AM
Nick at Pelican Parts's Avatar
Yes, I would replace the missing hose. It may causing an over-pressure in the crankcase. Causing seals to leak. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
