-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Battery and Connection Notes Replacement (http://forums.pelicanparts.com/mini-discussion-forum/968419-question-battery-connection-notes-replacement.html)
TonyC (guest) 08-30-2017 08:48 AM
What exactly am I looking for at the negative end of the cable for the IBS? I looked at Fig 7 as per a previous post, and my car has nothing but a plain wire to the negative terminal, ie. no L-shaped plastic unit, just the simple connection. Do I conclude then that my R56 does NOT have IBS? Thanks.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Battery and Connection Notes Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 08-30-2017 08:48 AM
If your negative terminal lacks additional small wiring and a plastic housing, you do not have an IBS.
- Nick
Luccia at Pelican Parts 09-08-2017 08:02 AM
Yep, you most likely do not have an IBS unit. If you want to have us double check, please post an image of your negative terminal for us.
