Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
E4jarhead (guest)
Guest
Posts: n/a
How do you open up and remove that clamp in figure 10. I have the nut removed but I can't figure out how to open or loosen up the clamp. Thanks.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Catalytic Converter Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-30-2017, 09:49 AM
Nick at Pelican Parts's Avatar
Press the bolt up as you open the clamp/ Or remove the bolt and lever the clamp open. You can't re-use the clamp.
- Nick
