Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
gabriel (guest)
Guest
Posts: n/a
If the antenna is broken should i have a higher reading or no reading at all? i am getting 4.4 or 4.6 each time i start to test the antenna
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Rear Comfort Access Antenna Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-18-2017, 06:29 AM
Nick at Pelican Parts's Avatar
4.4 and 4.6 are likely a good antenna reading.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Is your antenna mast broken or something? Why are you reading it?
Old 08-28-2017, 02:05 PM
