Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
GregR (guest)
Guest
Posts: n/a
Hi -
I have a 2008 Mini Cooper, base model. Error P0013 keeps appearing for camshaft position sensor - exhaust bank 1. I replaced the sensor and cleaned the contacts on the plug. Wiring looks good from what I can tell. After cleaning the contacts the CEL went off for 1 trip but came right back on at the start of the next trip. What would be the next suggested step?
Thanks,
Greg R
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 09-01-2017, 07:34 AM
Nick at Pelican Parts's Avatar
Check mechanical engine timing. The chain guides are likely worn, causing timing error.
- Nick
