Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Gnome88 (guest)
Guest
Posts: n/a
"That being said, the easiest way to determine the difference is to look at the slot in the center of the new wheel. If the slot curves as seen in Figure 1, it can be used on the Mk 1 2002-07 MINI's".
I'm a bit confused on this bit. Can this be viewed without taking the steering wheel off. Fig 1 doesn't show much of what to look for.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Changing Airbag and Steering Wheel - R50 MINI Cooper (2002-06) - R53 MINI Cooper S (2002-06)
Old 09-08-2017, 07:09 AM
Nick at Pelican Parts's Avatar
it can be viewed with the airbag removed.
- Nick
