Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Ken (guest)
Guest
Posts: n/a
R56 2009 base model N12. I have a fault code 2BE4 DME internal fault. No throttle reponse to gas pedal everyday 1st start. There is a website mentioned pressure sensor before throttle... However, is my N12 non turbo engine has no this sensor?
Very frustrating to troubleshoot this fault code 2BE4
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 09-08-2017, 06:25 AM
Nick at Pelican Parts's Avatar
Internal DME fault is a bad DME. if power and grounds to it are Ok and no outputs are shorting it, replace the DME.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
If it is in deed your DME let me know the last 7 digits of your vin.
Old 09-28-2017, 10:17 AM
