Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
sub (guest)
Guest
Posts: n/a
On the bewer r52/3 cars we have a camber adjustment nut at the outsides of the control arm. Do we reuse that nut or get a new bolt? Where should we tighten it down in the slotted hole?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Adjustable Rear Control Arm Installation (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 09-29-2017, 06:43 AM
Nick at Pelican Parts's Avatar
You can re-use it. Mark position before removing. Try to get it in similar location when installing. Then get vehicle aligned.
- Nick
