Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Wilbo (guest)
Guest
Posts: n/a
I just wanted to say thanks for this excellent guide! I just did the job on my 2007 cooper s and replaced the discs and pads at the same time. The only issue I had is that the ball joint fasteners were 21mm rather than 12mm but other than that the guide is spot on!
I had a few complications - I had to replace both disc protection plates, both arb links and a pothole damaged rim but now the job is done the car drives better than ever!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Front Wheel Bearing RWD Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 09-29-2017, 06:49 AM
Nick at Pelican Parts's Avatar
Thanks for the additional info and feedback. We appreciate it.
- Nick
